LabWindows/CVI
Can I use NI-IMAQ for IEEE-1394 (1.5) to manipulate the FIFO memory on board of a digital camera(Marlin 046C)?
I found it might need longer time to grab only one image from the digital camera. As my system needs to quickly acquire one image by one image, I am wondering if I can make use of the FIFO memory on board or trigger in an outer signal to solve the problem. But IMAQ for IEEE-1394 (version 1.5) looks no such function. Does anyone know how to use IMAQ for IEEE-1394 to grab one image quickly? Thanks in advance!
(2,948 Views)
You will be limited to the connectivity specs supplied by the manufacturers and in you case assuming USB, so no unless you supplier upgrades to some firmware options supporting IEEE-1394.
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(2,948 Views)
