LabWindows/CVI
Can I use RS422 with the labwindows rs232 sample?
I have a MDrive23plus motor. I want to transmit the instructions with a RS422. To transmit this instructions I use and modify the sample of RS232 in Labwindows. Can I use this?I mean, I can use this sample of RS232 to send Mdrive23 instructions (like "ma 200000" to move the motor) and send this instruction throught the RS422 without problems?Is it compatible?If not, could you send me an example of the program to send datas or instructions with the RS422?
Expecting you understand my question.
Thank you
(3,226 Views)
Dusplicated post: see here
(3,214 Views)
