LabWindows/CVI
Can I use Windows Sockets to communicate with CVI�s TCP function ?
Hello ,
I have registered a TCP server with CVI�s TCP server function . Now some other applications written with VC want to communicate with my application , I�d like to know if it can create such a TCP connection ?
(2,931 Views)
David,
The CVI TCP libraries perform regualr TCP/IP communication, anything that "speaks" TPC can communicate with a CVI application. A Windows Socket application should be able to communicate with no problem wiht the CVI application; just make sure that you interprete the data in the right format within the VC app.
Hope that helps.
Juan Carlos
N.I.
(2,931 Views)
