LabWindows/CVI
Can I use sockets to transfer data from my laptop to a simple server demo brd?
I'm using an Xilinx demo. brd. and can successfully communicate to it via TCP/IP while using Netscape. However, this board does not have an OS since it only executes code like a microcontroller. And it can only be configured as an server. I want to use LabWindows/CVI to transfer data from my laptop to the WAN and back down to this demo brd. Question � can I use datasockets in this configuration (i.e., Windows 2000 on a laptop trying to communicate with a dumb server using TCP/IP through the WAN?
(2,790 Views)
To use datasocket would require the demo board to understand the datasocket protocol. DS is based on tcp, but still requires the api on both the client and the server side. I would recommend using straight tcp/ip function calls, like ClientTCPRead() and ClientTCPWrite() to talk to the board instead.
Bilal Durrani
NI
Bilal Durrani
NI
(2,790 Views)
