LabWindows/CVI
Can I use the Scan format function to break up this string
I'm reading a string from an instrument which comes in looking like "$D025003147".  From this string I need to extract three integer values, the 2, the 5, and the 3 (the values I need will always be in the locations where the 2, 5, and 3 are in this example).  Can I do this with a single call to the Scan function (int Scan (void *Source, char Format_String[], ...); )?  I hate sounding like an idiot, but this function gets the best of me.  I think I could make good use of it if I understood it better.
Thank you
Stuart Van Deusen
(4,564 Views)
int  i1, i2, i3;
char a[16];
Option 1, with the use of a single Scan function as you want:
strcpy (a, "&D034007147");
n = Scan (a, "%s[i3]>%d[w1]%d[w1]%d[w2d]%d[w1]", &i1, &i2, &i3);
Option 2, directly getting character value ("0" is ascii 48, "1" is ascii 49 and so on):
i1 = a[3] - 48;
i2 = a[4] - 48;
i3 = a[7] - 48;
(4,550 Views)
Hello Stuart.
If you're not familiar with the Scanning function, it might be interesting to user the Wizard. You can find this program on your hard disk: C:\Program Files\National Instruments\CVI80\bin\fmtwz.exe. Note that the name of the directory CVI80 can be different on your system, depending on your CVI version. It is possible to add a shortcut to the LabWindows/CVI Tools Menu. To do so, select "Customize" from the Tools menu and add the program.
(4,533 Views)
Some comment on this Scan function which is powerful and painful at the same time Smiley Wink:
                  |      +-----+-----|------+---> Read an integer consuming one byte in the source
                  |                  +----------> Read 2 bytes from the source discarding them
                  +-----------------------------> Read the string starting from the 3rd character
(4,530 Views)
Thank you both very much for the replys.  Roberto, not only have you provided me with code which does exactly what I want, but your explanation will help me to use the function in the future (I learn much better by applying other examples to my situation).  Wim, I didn't know that wizard was there.  It will also be a good tool in helping me to make good use of this function.
Stuart Van Deusen Insert Smilies
(4,513 Views)
