I use Ni-DAQ, no DAQmx. My version of labwindows is 6.0 or 6.1 (and, by
the way, the FFT() function has a memory leak. Is there a patch for
that?).
I'm trying to continuously output white noise and read the output after
it's been put through a filter. I've written a test case using the Easy
I/O for Daq library, and it seems to not like the idea of
multithreading. Would the normal NI-Daq libraries be any different?
This code actually tries two differnt things. It tries running the
output in its own thread and doing the reading in the main thread. Then
it tries running the output and the input in separate threads,
whereupon I get an error stating that the board is improperly
configured.
Would putting the output in a timer solve my problems?
Thanks to those who take the time to answer,
Jason Espinosa
University of Miami Astrophysics lab.
-Jason Espinosa
LabWindows 6.0
PCI-6036E
