LabWindows/CVI
Can a Labview instrument driver be converted to a LabWindows Driver???
I saw that a LabWindows/CVI driver can be converted to Labview, can the opposite be done?
(3,449 Views)
Hello TE-Gregg,
The best way to use your LabVIEW instrument driver in CVI is to compile your LabVIEW code to a dll, and call the dll from CVI. There is no direct conversion function to import a LabVIEW driver to your CVI code. To elaborate slightly, when you create an instrument driver in CVI and bring that to LabVIEW, CVI is actually creating a DLL which is imported by LabVIEW. So the reverse would hold true regarding importing a LabVIEW driver in CVI.
You may want to check out our Instrument Driver network here to see if your particular instrument has a CVI driver already built. The instrument driver network can be found at http://www.ni.com/devzone/idnet/ . If you are unable to find drivers here, you might also want to consider contacting the manufacturer of the device.
Hope this helps.
Travis M
Travis M
LabVIEW R&D
(3,421 Views)
Travis,
Thanks for the reply. I've checked the Inst. Driver network and the driver I wanted was created in Labview. I can create my own, but I didn't want to reinvent the wheel. I will try your suggestion first.
Gregg
(3,415 Views)
The following link discusses Labview and CVI interoperability with
instrument drivers:
http://zone.ni.com/devzone/conceptd.nsf/webmain/55FE4BB06CD115BA86256CAF005EF71C
(3,403 Views)
