LabWindows/CVI
Can any one help nme in implementing a DDE server?
I want to implement DDE server in one of my application.I am using Register DDE Server  from CVI library to register the application as DDE server.I am having no idea how to implement the call back in the DDE server.As when i am trying to connect to the server from another application acting as DDE client its giving error as conversation not established(error no.-26).
(4,225 Views)
did you check the forum, e.g. here ?
(4,220 Views)
Hi,the link you have given does not have any server implementation.Its only the client.It also doesnot describe about how the callback function for the Server should be written.Both my application are in CVI.One acting as server and the other as client.
(4,190 Views)
Accepted by topic author Himanshu_77
the link in the previous post includes the link
http://zone.ni.com/devzone/cda/tut/p/id/4024
with the title
Creating a DDE Server Application in LabWindows/CVI
In particular it explains how to use a DDE callback
(4,186 Views)
I have the same issue of conversation not established with LNS DDE server .
Did you fix this?
And I assume that the link given in the solution has expired.
Can you please help me implementing the same?
Thank you
(2,627 Views)
