LabWindows/CVI
Can anyone help me with activex and variants?
This is the activex function,
HRESULT CVIFUNC DATAQSDKLib__DDataqSdkGetData (CAObjHandle objectHandle, ERRORINFO *errorInfo, VARIANT *returnValue);
ERRORINFO *errorInfo;
VARIANT my_data_1;
error_code = DATAQSDKLib__DDataqSdkGetData (dataq_handle, errorInfo, &my_data_1);
Does anyone know how do I get the data out of my_data_1?
(3,635 Views)
Look under the library menu for ActiveX Library.  In it you will find a section name Variant Related Functions which can be used to assign and retrieve values from the variant format.  In that section you will find Querying the type of a variant.  Use the entry for Variant Get Type which is the function CA_VariantGetType() to determine what the variant variable holds.   You can then look under Retrieving values from Variants for the function to assign the value to the more familiar C types, such as CA_VariantGetFloat() if the variant holds a float.
(3,597 Views)
Greetings jeff at HCT!  Thanks for contacting National Instruments!
Have you tried exploring the "Libraries»ActiveX Library»Variant Related Functions" within the functions library in CVI?  There's a section within that library that contains all the functions necessary for extracting values from Variants.
Message Edited by Derrick S on 10-30-2007 03:24 PM
Derrick S.
Product Manager
NI DIAdem
(3,598 Views)
