LabWindows/CVI
Can automatic register a dll?
Can automatic register a dll when installing an application which is using the distributing tool packed?
David
(3,814 Views)
Yes. In the Edit Distribution dialog, on the tab with the file browser, double-click (or select "<Filename> Options..." from the right-click menu) the file you want to register, and set the "Register as ActiveX Server" option to "Yes".
Mert A.
(3,786 Views)
You might want to consider whether or not the DLL in question is an ActiveX DLL.  If it's not "ActiveX" (is a COM or ActiveX server)  then you do NOT want to register it.
If you try to register an non-activex DLL it will try to do it and it winds up making a mess in the registry which you then have to manually rip out.
Menchar
(3,708 Views)
