LabWindows/CVI
Can customize the cvi's panel ?
Hope to use a customized window instead of using the classical, but each panel always has the same Windows style , can customize the panel created by CVI?
David
(2,923 Views)
Hello David,
The look-and-feel of your panel in CVI, will adhere to the settings you have for your operating system. For instance, if you select Windows-style panels, and are running under the WinXP theme, you will notice that the panel title bar in CVI is displayed in blue like the other application title bars.
I hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(2,901 Views)
