LabWindows/CVI
Can display number in hex format with the textbox control?
There is an array defined as:
unsigned char buf[20];
Now want to display it with the textbox control, the dispaly format is as this format: 01 1E 30 EE A0..., how to do with the control?
David
(3,544 Views)
If you start from the number, you can format the string this way:
#include <ansi_c.h>
static char	msg[64];
static int		n;
static int		msk1, msk2, msk3, msk4;
msk1 = 0xFF;
msk2 = 0xFF00;
msk3 = 0xFF0000;
msk4 = 0xFF000000;
n = 12027;
sprintf (msg, "%02X %02X %02X %02X", (n & msk4) >> 24, (n & msk3) >> 16, (n & msk2) >> 8, n & msk1);
The code above can be pasted in Interactive Execution Window and executed as is. In your program you'll have to SetCtrlVal 'msg' to the textbox.
(3,536 Views)
