LabWindows/CVI
Can somebody give me a example of ADO in CVI ?
When I create the fp file of Ado in Create Automation
server menu,it generates a lot of functions without
appropriate help,I still can't use it after hours of
trying,Can Somebody help me? Thanks First.
(3,049 Views)
If you are having difficulties creating an ActiveX server, I would refer to the attached document for an in-depth discussion on this topic. Note, this document is current as of CVI 6.0. If you are using CVI 5.5, the concepts will remain the same, but some of the menu/dialog items may have changed.
regards,
Eric Meyer
(3,049 Views)
