LabWindows/CVI
Can somebody please tell me the steps to Program USB 6211 with C. Will I get the software to program the device along with the drivers CD that I got when I purchased the Device?
Hi Brain,
I tried executing the example program for analog continuous wave generation. I was sucessful in generation of the wave, but when I stop the execution my DAQ board still outputs a DC voltage.
But I want the output to go to Zero once I'm done withthe execution. Is there something else that I need to add to the code to acheive this.Please help me.
Diya
Message 21 of 30
(1,529 Views)
Diya,
With Analog Out the card will always output the last voltage it was given.  If you want to have it go to zero after you are done, you can write a 0 to your line at the end of the program.
I hope that helps.
Brian
Message 22 of 30
(1,528 Views)
Brain,
I tried doing that but I'm seeing an error message which says "Specified resource is reserved".
I want my wave to be continous and just go to zero when I hit enter to end program.
Can you help me out with the syntax of the program? i.e. where should i give the statement data=0.0; in my code?
Diya
Message 23 of 30
(1,525 Views)
Diya,
In order to get it to output a zero, I changed the error section to write a zero and then output it before it stops the program.  Here is how I modified it:
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ){
//DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxWriteAnalogF64(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,0,NULL,NULL);
DAQmxStartTask(taskHandle);DAQmxStopTask(taskHandle);DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
And that would bring my output back to zero.
I hope this helps.
Brian P.
Message 24 of 30
(1,508 Views)
Hi Brain,
I've the same problem back again.. It just worked for once and it is not working again.. 😞
This is my code :
#include <stdio.h>#include <math.h>#include "NIDAQmx.h"
#pragma hdrstop
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
#define PI3.1415926535
int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData);
#pragma argsusedint main(int argc, char* argv[]){
int       error=0;
TaskHandle  taskHandle=0;
float64     data[100001];
char        errBuff[2048]={'\0'};
int         i=0;
int freq;
printf("Please enter the Desired Frequency\n");
scanf("%d", &freq);
for(;i<100001;i++)
data[i] = 5*sin((double)i*2.0*PI* freq/240000.0);
/*********************************************/// DAQmx Configure Code/*********************************************/DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao1","",-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",240000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,50000));
DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
/*********************************************/// DAQmx Write Code/*********************************************/DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,50000,0,-1.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
/*********************************************/// DAQmx Start Code/*********************************************/DAQmxErrChk (DAQmxStartTask(taskHandle));
printf("Generating voltage continuously. Press Enter to interrupt\n");
getchar();
getchar();
Error:if( DAQmxFailed(error) )
if( taskHandle!=0 ) {
// DAQmx Stop Code
  DAQmxWriteAnalogF64(taskHandle,240000,0,10.0,DAQmx_Val_GroupByChannel,0,NULL,NULL);
  //DAQmxClearTask(taskHandle);}
getchar();
return 0;}
int32   error=0;
// Check to see if an error stopped the task.
DAQmxErrChk (status);
Error:
if( DAQmxFailed(error) ) {
printf("DAQmx Error: %s\n",errBuff);}return 0;
Message 26 of 30
(1,492 Views)
Diya,
I am sorry that it is not working for you again.  When you say not working, what exactly do you mean, are you getting an error?  What has changed from when it was working?
I looked at your code and everything seems to be in order so I am thinking that we do that self test again, where we output the data and then read the data back in using a test panel.
Please let me know what errors you are getting if any.
Brian P.
Message 28 of 30
(1,475 Views)
Hi Brain,
I tried executing the code even using the test panel method you suggested earlier. Still didn't work. 😞
Previously when I posted that it worked and the reason behind it might be, when I hit enter to abort the generation of the sine wave, maybe I got lucky and it stopped exactly at the point zero and it seemed to be working But after I executed the code couple of times it never worked again, i.e.. It never ended at zero. It is giving me some DC offset values but not going to Zero.
Diya
Message 29 of 30
(1,468 Views)
Hi Diya,
I ran your code and it executed properly as it zeroed after pressing Enter to interrupt. Does the waveform (prior to zero) look correct in the AI Test Panel? Could you take a screenshot of the test panel after you press Enter?
Kind Regards,
Message 30 of 30
(1,452 Views)
