LabWindows/CVI
Can't find .h!
I'm sorry for my "stupid" posts, but i got some problems with LW..
I think it's an easy problem, but i don't know how to solve it, but i need too!
Therefore i ask here, and hope for nice answers...
I got an .uir-file, but when I generate all code, it doesn't create any .h-file, which it supposed to do (i think)
so the problem is when i should compile the .c-file, and it doesn't find the header!
Should i try to write it by my own, or is it something i can do?
/daniel
(2,856 Views)
The header file associated with an UIR file is not created while generating code: it is created during UIR creation. So, if you copied an UIR from elsewhere to your project without the associated H file you must simply resave the uir to generate the corresponding header file (you may need to make some little modification to the UIR to enable save option).
(2,847 Views)
