LabWindows/CVI
Can't open .prj files CVI 2009
Running CVI 2009 and everything had been running fine for weeks.  Shut down test program that was running.  Installed my license device and went to my .prj file to open it up in debug mode.  When I double clicked on it, Windows says it can't find the file, even though it is sitting right there in explorer, it will not open it.  Tried several other .prj files and it does the same thing.  Tried opening CVI by itself and then loading the .prj file, but the splash screen comes up and then it never does anything else.  Rebooted several times (running XP SP3), then finally tried to do a repair of the CVI install.  This didn't help and it did the same thing.  Then deleted everything and did a fresh install...it still says it can't find the .prj file.  It seems like something has gotten corrupted in my Windows install maybe??  Probably going to try and re-image the machine, but trying to figure out what happened.  Anyone seen anything like this ever before???
Thanks for any info...
EDGE
(3,328 Views)
Hi EDGE,
I haven't run into a similar error in the past but keep us posted on if reimaging the machine resolves the issue.
Best Regards,
Swathi B
(3,291 Views)
