01-24-2011 06:18 AM
Hello Mateusz,
On the test PC we have installed DAQmx, but revision 8.1 (for all test PC we use the same set of drivers -DAQmx 8.1, NI-CAN 2.6.2, NI-PAL 2.4...).
So the application that fails under CVI IDE is a real production test program with NI-DAQ and NI-CAN hardware/software installed.
Regards
01-24-2011 10:00 AM
Dear Petko,
thank you for clarification.
What I still don't understand is why do you think that upgrading to CVI 2010 won't help. It might not be DAQmx fault, but there are many other reasons for the error appearing that might have been fixed in newer version of CVI. If the error suddenly appears after some time, there must be some change in the system. You said, that your system setup worked for some time and the problems appeared recently on many machines. My guess is that there must have been some update (to the Windows itself or any other software that was installed on all of them) that causes the malfunction.
