LabWindows/CVI
Can't stably write to COM port
Hello,everybody.
I wrote a program using CVI5.5 232 library,in my program I install a COM callback function (Function InstallComCallback()),in which bytes is continuously received(using function ComRd()) and processed.During the processing I need to send some bytes through COM
port some time(ComWrt()).But sometimes I can't send the data to destination stably,in debug enviroment,I am sure that the program sentence including ComWrt() was executed,but the data was not physically sent out immediately,they still remained in the output queue likely.
My OS is Chinese win2000(sp3),and I initiate Com port(OpenComPort()) with baud rate 9600.
Thanks in advance.
(2,891 Views)
Hello
Try running one of the serial examples installed with CVI. This should allow you to check whether its something wrong with your application or not. They are installed under ..\CVI\samples\rs232\
Also try doing simple COM reads and writes and use the GetOutQLen() function to check how many bytes are available in the output port
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,891 Views)
