LabWindows/CVI
Can the CVI7 come true "splitter"?
Hi!
Can the CVI7 come ture the function - it is similar to splitter component in Delphi? That is to say,
The component placed between aligned controls allows users to resize the controls.
Used with components like graph and list boxes, splitters can divide a panel into several panes
with multiple controls on each pane. For example, There are two graph in a panel, I can resize them through
"splitter" by moving mouse.
If CVI7 can do it, pls tell me!
Thanks.
(3,312 Views)
CVI 7.1 has aplitter controls like you describe. CVI 7.0 does not.
Luis
NI
(3,308 Views)
You can download the CVI 7.1 eval version from here to see if it does everything you need.
Hope this helps
Bilal Durrani
NI
(3,290 Views)
