LabWindows/CVI
Can the PCI-8532 use at Labwindows/CVI programming environment
Hi
I am a new use for NI PCI-8532 card, I installed the NI industrial communication for DeviceNet, bur I can't find any Labwindows/CVI sample code for it. So I am not sure the card can programmed by the CVI and where can find some sample code.
Finally I want to know how to config the PCI-8532 in NI-MAX, like set the interface name/baud rate and so on....
(2,327 Views)
Good day,
For the LabWindow example, you may refer to the knowledge base as link attached
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MwOSAU
For the DeviceNet, please find the correct driver with your LabWindow version in the link below:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/zhs/pg/1/sn/ssnav:dwl/q/NI%208532/
I think after installed the correct version of the driver, your configuration problem with NI MAX will be solved. 😄
Looking forward of your reply. Marks as solution if the problem solved 😄
National Instruments | 美国国家仪器
Applications Engineer | 应用工程师
Technical Support Engineer | 技术支持工程师
(2,288 Views)
