LabWindows/CVI
Can we display html file directly?
Let say we have to open a html file (in local PC) with containing only text, can we display them directly by any ActiveX codes (is it required a special create ActiveX object?) without worry any html tags?
Thanks for any help
(3,964 Views)
Hi plit string,
You could use our Internet Explorer example "iedemo.prj" that uses ActiveX to display HTML, so you don't have to do any parsing.  You can find this in the Example Finder by searching for "internet".
Gavin Fox
Systems Software
(3,937 Views)
As an alternative you could consider using OpenDocumentInDefaultViewer function in the Programmer's Toolbox which opens your document in the default web browser.
(3,929 Views)
I did try your suggestion to open a .html file , but it shows only an empty MS Dos window. Do you know why?
(3,899 Views)
Thanks for the guide, I am working on it
Many thanks
(3,898 Views)
