LabWindows/CVI
Can we load/import external DLL created by VB.net?
I have a DLL created from VB.net. I did register it successful in the same folder of my CVI project ... However, I could not find the way to import/load it ... in order to use it!
Does someone know how to do it?
Thanks for any help Smiley Sad
(4,580 Views)
Hi plit string,
Check out my post here.
Best Regards,
Jonathan N.
(4,576 Views)
Thanks for your post, it will help me a lot to use .net from now on Smiley Happy. However it still does not help me to load/import a VB.net dll ... in case I have to create one as requirement Smiley Indifferent ... might be you have another link for this?
(4,571 Views)
Hi plit string,
Perhaps I am misunderstanding your terms of loading/importing a VB.NET DLL. When you use the .NET Controller Wizard, you are creating a wrapper around whatever .NET assembly you want. The first time you make calls to the assembly (usually some initialize function; See our dotnet examples in the <CVI>\samples\dotnet\ directory) the assembly is loaded into memory.
If you are referring to using LabWIndows/CVI as a .NET container, this functionality doesn't exist yet.
Maybe you could clarify a little?
Best Regards,
Jonathan N.
(4,569 Views)
I meant that if I created a DLL from VB.net and want to use that DLL with CVI (without using .NET Controller Wizard) ... what should I do?
Thank for being patient with me
(4,564 Views)
Hi plit string,
In most cases, you primarily use the generated wrapper functions (created by the .NET Controller Wizard) to program with .NET assemblies in LabWindows/CVI. However, you can use the .NET Library functions (In the Library Tree, expand Libraries » .NET Library) to call .NET assemblies. With this library, you can register assembly paths, load assemblies, create and call .NET objects, etc.  Refer to the LabWindows/CVI Help for more information on the .NET Library.
For example, you could use the function CDotNetLoadAssembly() to load the assemb
ly.
Best Regards,
Jonathan N.
(4,561 Views)
