LabWindows/CVI
Can you change the buffer size when using InetPing in CVI 7.1.1?
I was wondering if anyone knows if there is a way to change the buffer size when using the InetPing function in the Internet Library? For example; when you use the ping command you can pass a "-l" parameter to specify the buffer size. I was also wondering if the InetPing function uses the default buffer size of 32 bytes?
Thanks.
Mark
(3,629 Views)
InetPing() does not send a data payload with the ICMP, so the data buffer size is 0. This is not user configurable option. I'll make this information available in a KB. Is this causing a problem for you?
Bilal Durrani
NI
(3,621 Views)
Hi Bilal,
Thanks for your reply. I'm developing an application that monitors download rates, and the users want the ability to surf and ping. I was hoping that I could increase the buffer size on the ping and use the response time to calculate ping rates.
mark
(3,605 Views)
You can file this as a product suggestion by going this link and going to Product feedback.
As a workaround, you should be able to use the ICMP functions in the Windows SDK to be able to set up a ping based on the specificications you need.
Bilal Durrani
NI
(3,581 Views)
