LabWindows/CVI
Can you improve the speed of my CSV Reader and Writer?
yor way is fast but we have lost support for value with CR inside it, am i wrong?
thank for the help
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 11 of 24
(3,825 Views)
no, i'm wrong. it's fully working.
the only thing i have to correct is the clear string
	//clear strings
	for(i = 0; i < numero_stringhe; i++)
		stringa_destinazione[i][0]=0;
whit my one
	for(i = 0; i < numero_stringhe; i++){
		lunghezza_stringa = strlen(stringa_destinazione[i]);
		memset(stringa_destinazione[i], 0, lunghezza_stringa);
because with your only the first character is set to 0
Message 12 of 24
(3,823 Views)
I have not tried to insert a CR but it should be managed here (I hope it works) :
case '\r':
			case '\n':
				if(inquote){
					//cariage return or line feed inside quote
					//insert line break and parse next line
					stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = '\r';
					stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = '\n';
					carattere = lines[++riga_partenza];
				else
					//end of line
					stringa_destinazione[stringa_in_corso][index_stringa_in_corso] = 0; //terminate string
			break;
 I think there is still room to improve the parser, the first step that split the buffer into lines is not required. The state machine can handle all CR so it is possible to replace the array of lines by a buffer containing all the file content.
Stef
Labwindows/CVI user since version 4.0
Message 13 of 24
(3,820 Views)
You don't have to clear all the string content, in C a string is terminated by a 0. So if you write a 0 at the first position the string is considered as empty.
Message 14 of 24
(3,818 Views)
ok but if i have in memory something like "351.12" and i set to '0' only the first char i will have "'0'51.12" in memory.
after if i change the value of that string with, for example "1.2" i will have "1.2.12" and i will have an error in the afot()
Message 15 of 24
(3,816 Views)
if your string contains '351.12', in memory you get 351.12\0 . When you will write '1.2' inside the string in memory you will get 1.2\012\0, and your string will end at the first encoutered 0. The only thing that you have to take care is to terminate properly your string by a 0 character.
Message 16 of 24
(3,814 Views)
sure, i don't know why i was thinking that!
too much Panettone during holydays! Smiley LOL
Message 17 of 24
(3,808 Views)
one error found in my code:
when i look for the "#VALUE:" string and i find it i have to increment the variable by 1 because i use it not only to get the first numeric value but also tu calloc the buffer that contains it
	do{ risultato_find_pattern = FindPattern(lines[numero_riga_value], 0, -1, "#VALUE:", 0, 1);
	}while( (risultato_find_pattern < 0) && (numero_riga_value++ < 100) );
	numero_riga_value++;
Message 18 of 24
(3,805 Views)
hi stef, i've seen that one control in the CSV reader is missing.
in my version i check if i've reached the maximum number of readable column and i will parse it but don't store.
in your version there isn't this control and if i have more column than expected i will get an overflow error.
now i have to do some other job, when i have some time i will fix it
Message 19 of 24
(3,797 Views)
sorry for the flood, it was easy and i have already done it
int leggi_riga_csv_v2(char **lines, int riga_partenza, char *stringa_destinazione[], int numero_stringhe, int formato)
	char delimitatore[2] = {',',';'};
	int stringa_in_corso = 0;
	int index_stringa_in_corso = 0;
	int inquote = 0;
	int i = 0;
	int error = 0;
	char *carattere = NULL;
	//Point to begining of current line
	carattere = lines[riga_partenza];
	while(*carattere && !error)
		switch(*carattere){
			case '\"':
				if(index_stringa_in_corso == 0){
					// se come primo carattere ho una " allora e' una stringa speciale
					inquote = 1;
					carattere++; //skip quote
					carattere++; //get next character
				else{
					if(inquote){
						//Check for double quote
						carattere++;
						if(*carattere == '\"'){
							if(stringa_in_corso < numero_stringhe){
								stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = *carattere; //concatenate quote
						else if((*carattere != 0) && (*carattere != delimitatore[formato])){
							error = 1; //Quote string not followed by delimiter or end of string !
						else{
							//end of quoted string
							//parse next string
							stringa_in_corso++;
							index_stringa_in_corso=0;
					else
						error = 1; //Quote inside unquoted string !
			break;
			case ',':
				if(formato == 1){
						stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = '.'; //replace , by .
				else
					//parse next string
					stringa_in_corso++;
				carattere++;
			break;
			case ';':
				if(formato == 0){
						stringa_destinazione[stringa_in_corso][index_stringa_in_corso++] = ';';
				else
					//parse next string
					stringa_in_corso++;
				carattere++;
			break;
			case '\r': // CR = 0x0D = 13
			case '\n': // LF = 0x0A = 10
				if(inquote){
				else{
					//end of line
			break;
			default:
				//copy others characters in destination string
				carattere++;
			break;
	return riga_partenza;
Message 20 of 24
(3,795 Views)
