I have two application (LabWindowsCVI) that excange data with DataSocket server. When an application write data in the server end the slave application not read it, the data stay in the server. I don't have found a system from the server application to verify if the slave application have read the data. Is possible cancel the data that remain in the server ? Otherwise this data is readed from the slave application in a wrong time.
You might want to write simpler example programs, or just run the example programs that ship with CVI to see if you still see the delay in the communication, and determine the cause of the delay.
Mika Fukuchi Application Engineer National Instruments
