LabWindows/CVI
Cannot add Files to Source Safe from CVI
When I try to add a .c file into my Source Safe database from CVI using "Tools->Source Code Control->Add to Source Control" I get an error message stating: "File xxx.c could not be mapped to the Source Safe Project $/MyProject"
I looked on the help and it said: "You must have the file in VSS before continuing the operation.
Click Yes to copy the file to the specified project and continue. Click No to cancel the operation."
I do not have Yes and No buttons, just OK, "OK All" and "Help"
I even added the file outside of CVI to Source Safe, but get the same error message.
Has anyone else had these problems adding a file?
Thanks a lot
Russell
Message 1 of 1
(3,010 Views)
