LabWindows/CVI
Cannot dimmed an activex control
    I create an ActiveX command button and set "Initial Dimmed" checked , "Enabled" property to False in Edit ActiveX Control panel. When I run the cvi project, just label of the command button is dimmed and command button control is not. How to make both label and control are dimmed?
(3,728 Views)
Hello -
Thanks for reporting this, it's been reported as a bug with ID 238634.  Unfortunately, there is no clean workaround available at this time.
NickB
(3,681 Views)
