LabWindows/CVI
Cannot find icon file
The message "Cannot find icon file" occurs when I try to compile my project (CVI551).
What it means ?
Thank you
(6,342 Views)
It means that you specifid an icon file for your project (executable) but it is no longer at the location you previously specified. To remove the icon file or change the path to it, go to Build >> Target Settings and make sure the entry "Application Icon File" is empty. If you indeed want an icon file, then browse to a valid path and rebuild your project.
Azucena
(6,342 Views)
