LabWindows/CVI
Cannot set the ATTR_TEXT_BGCOLOR in SetTableColumnAttribute
I tried to set the ATTR_TEXT_BGCOLOR for a column of a table by calling:
SetTableColumnAttribute  (panel, TABLE, column_no, ATTR_TEXT_BGCOLOR, VAL_YELLOW);
but it doesn't change the background color to yellow.  However, if I use the SetTableCellAttribute call for every cell in that column then it works.  Is this a "bug" in SetTableColumnAttribute?  BTW, I'm using LabWnidows/CVI Ver 9.1.1 (450).
TIA
(3,149 Views)
As you can see here, this is expected behaviour as SetTableColumnAttribute does not affect existing cells. Use SetTableCellRangeAttribute instead.
(3,146 Views)
