LabWindows/CVI
CanvasDrawText() fails with code -14
The output of the following code snippet is a line drawn in the canvas control, "CanvasDrawText() failed with code -14", then another line drawn in the canvas control. The panel handle, control ID and all coordinates are valid. Why is CanvasDrawText() failing?
char sMessage[200];
int iRet;
Point TextPoint = {0,0};
Point LinePoint = {0,50};
CanvasDrawLine( pGraphic->phPanel, pGraphic->iControlID,
TextPoint, LinePoint );
iRet = CanvasDrawText( pGraphic->phPanel, pGraphic->iControlID,
"Sample Text", VAL_APP_META_FONT, MakeRect( 20, 30, 150, 200 ),
VAL_CENTER_JUSTIFIED );
if ( iRet < 0 ) {
sprintf( sMessage, "CanvasDrawText() failed with code %i", iRet );
MessagePopup( "Message", sMessage );
} else MessagePopup( "Message", "CanvasDrawText() passed" );
pAxis->Axis.Line.Start, pAxis->Axis.Line.End );
(3,273 Views)
Hi Glenn,
Please try to refrain from posting duplicate questions. This issue has already been addressed in this thread.
Thank you,
Scott Y
NI
(3,264 Views)
