LabWindows/CVI
Change color of window background in CVI2015
I hope that the answer is easy but I can't find a way to change the background of one of the sub-windows of "Variables and Call Stack" window in CVI 2015 (see attached image).
I use a "dark theme" and in CVI 2012 I don't have this issue. I imported the color scheme from CVI 2012 to CVI 2015, so I don't understand the reason for this behavior.
The problem is that since my theme is dark, the text color is white and I can't read the text over a white background.
Can someone help me?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(7,996 Views)
NI technical support verified that this is a bug. CVI2013 shows the same bug too.
CAR #587244 has been opened
Vix
Using LV from 7
(7,888 Views)
You guys should track 439323 instead. The other CAR was ultimately identified as a duplicate of this one, which means that it'll be this one that will show up in the bug-fix list and the known-issues list.
(7,213 Views)
CAR #439323 has been fixed in CVI2017
Vix
Using LV from 7
(6,669 Views)
