LabWindows/CVI
Change detection in combination with additional digital input
Hello everyone,
I am using change detection for several digital lines and am trying to create an additional task to read a different digital line periodically. However, when both tasks are started I get the following error message:
Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
Property: DAQmx_SampClk_Src
Property: DAQmx_SampClk_ActiveEdge
Source Device: Dev1
Source Terminal: Change Detection Event
Required Resource in Use by
Source Device: Dev1
Source Terminal: PFI0
Destination Device: Dev1
Destination Terminal: di/SampleClock
Status Code: -89137
I am generating a clock using the card's frequency generator as a sample clock for counters and the digital input I'm trying to acquire. This freqout clock is routed to PFI0. The error message is not very explanatory to me, so I hope that somebody can help me with this error.
(2,663 Views)
Accepted by topic author Alkali
Hello Alkali,
only one task with timing can be used for the digital inputs so only change detection or continuous input can be used.
How Many Different Tasks Can I Run On My Multifunction DAQ Card?
Why not make change detection for all or acquire all with a fast rate so every change is shown?
best regards
Alexander
(2,634 Views)
