LabWindows/CVI
Change font in application menu
I need to change the default font used for the menu
so that it is not dependent on the font set in the Windows system.
The default font used for menu in Windows XP(Tahoma) doesn´t support some characters(ř,á,ý,�)
I have Labwindows/CVI 5.5
ovrabek/CZ
(3,543 Views)
Several references make the point that CVI uses the default Windows font for its menus. See this link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000000C960000&UCATEGORY_0=_318_&UCATEGORY_S=0
You can change the Windows menu font using the control panel Display >> Appearance >> Item >> Menu >> Font.
I can't find anything in CVI 7.0 that's any diferent.
(3,543 Views)
Thank you.
Other application(Iexplorer ..) shall they same problem.I have an idea,simulate menu as canvas plus dynamic panel.
ovrabek/CZ
-I am sorry for (CZ/EN) translation grammatical mistakes
(3,543 Views)
