LabWindows/CVI
Change the size of a check box inside a tree control
Hello everybody, I have a cvi tree containing check boxes as cell types. The problem is that at small display resolutions (e.g. 1024x786) its hardly possible to recognize if the box is checked or not, because the check mark only consitst of a few pixel. I tried to increase the default cells font size, but it seems to have no effect on the size of the check boxes. Does anybody know how to increase the size of a check box inside a tree control? Thanks, Marlon
(5,871 Views)
I have reproduced what your have posted  but I can only change(Checkbox) up to size 15. Please let me known if  the checkbox you have only look like this one on the screenshot? If not then you should be able to change the size in the properties. see picture
(5,778 Views)
(5,774 Views)
