LabWindows/CVI
Changing CVI Controls size by Screen Size
I'm trying to do something and i don't know if it's posssible ,
I have panelMain as my panel handle , when i start my program and i show my panel i'm maximizing the soft screen to maximum with :
SetPanelAttribute(panelMain,ATTR_WINDOW_SIZE,VAL_MAXIMIZE) i do so in order to make this soft be generic for every screen size...
but when i do so all the buttons go to the left of the screen while leaving me a blank gray surface in the right.
what i want to know is can i make a generic panel like in the office software or other software which the buttons change this size according to the screen size ?
if you have other solution it will be grate also...
thank you
Kobi Kalif
Software Engineer
(5,392 Views)
did you have a look at ATTR_SCALE_CONTENTS_ON_RESIZE?
(5,389 Views)
thanks for the answer ,
yes i tried it  but situation is different.
ATTR_SCALE_CONTENTS_ON_RESIZE affects when you resize your window with the mouse or something like that...
i want my soft to be automated maximized on the screen and the button to be scaled according to window size..
Kobi Kalif
Software Engineer
(5,386 Views)
Accepted by topic author Kobi_K
Well, this is not exactly true: according to the help for this attribute:
Specifies whether the contents are scaled when the panel is resized. This applies to programmatic resizing, resizing in the User Interface Editor, and resizing by the end-user.
An alternatirve is to set Resolution adjustment property in the UIR editor for the panel to 100%: this should ensure the panel is automatically scaled to screen resolution regardless its original dimensions.
(5,368 Views)
