LabWindows/CVI
Changing X-scale on StripChart resets graph
I was wondering if there is a way to change the x-range on a stripchart without resetting the traces. Currently, I use:
SetCtrlAttribute(panel,control,ATTR_POINTS_PER_SCREEN, XRANGE)
The only problem is that the stripchart automatically sets the origin at the current time (I am using absolute time scale) and resets the graph. Is there any way to change this behavior, because the only thing I can think of to do is store all of my data in memory and replot everytime the user changes the xscale... which wouldn't work too well due to the large amounts of data I have.
(4,162 Views)
Hello Baselerd,
I have not found a way to modify the range of a stripchart's x-axis without making the chart redraw the traces.  It seems it must redraw based on the design of the control.  Sorry for the inconvenience.  Have a great day!
Best Regards,
Software Engineer
Jett R
(4,116 Views)
Alright, well thanks anyway.
Alex
(4,084 Views)
I've just added a new product suggestion.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,561 Views)
