LabWindows/CVI
Changing graph legend font size in CVI
Is it possible to change graph legend font size (created by LGCreateLegendControl and LGInsertLegendItem command)? Thank you...
(3,357 Views)
Yes, you can use CreateMetaFont to create a new meta font name. Then, you can use LGSetLegendCtrlAttribute to set the LG_ATTR_META_FONT attribute to the new meta font name. Note: There is a mistake in the function panel for LGSetLegendCtrlAttribute, it puts in LG_ATTR_FONT instead of LG_ATTR_META_FONT, so you will have to manually edit that to get it to work.
Your code will look something like this:
CreateMetaFont ("LegFont", "Arial", 16, 0, 0, 0, 0);
LGSetLegendCtrlAttribute (panelHandle, legendCtrl, LG_ATTR_META_FONT, "LegFont");
Best Regards,
Chris Matthews
(3,357 Views)
