LabWindows/CVI
Changing the color of the progress bar after calling CreateProgressBarDialog
I like the functionality of the progress bar dialog in the Programmer's Toolbox but was a bit annoyed that the color attributes were not exposed so they could be changed.
So here is a bit of code I put together to do this, I hope some of you will find it useful:
// This struct is defined in toolbox.c but not exposed
// you will need it to access the control handle
typedef struct
    int panel;
    int progressIndicator;
    int cancelRequested;
    int cancelButton;
} *ProgressDlg;
int progressDlgHndl;
ProgressDlg progressDlg = 0;
progressDlgHndl = CreateProgressDialog ("Operation Completion Status",
 "Estimated Percent Complete", 0, VAL_NO_INNER_MARKERS, 0);
GetPanelAttribute (progressDlgHndl, ATTR_CALLBACK_DATA, &progressDlg);
SetCtrlAttribute (progressDlg->panel, progressDlg->progressIndicator,
 ATTR_FILL_COLOR, VAL_GREEN);
 ATTR_FILL_HOUSING_COLOR, VAL_LT_GRAY);
ProcessDrawEvents ();
// Do your operation and update progress...
DiscardProgressDialog (progressDlgHndl);
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
Message 1 of 1
(3,505 Views)
