LabWindows/CVI
Changing the name of serial communication example in lab windows. Urgent help required
I am using the example of getting data from rs 232 in lab windows. I want to use this in my final year project that's why I want to change its name that appears as  "serial communication example" how can I change its name and how can I make its exe file that will run on any system even without lab windows.
How can I modify this example to save the data. I am very new to lab windows, I was using hyper terminal previously.
(4,875 Views)
(1) Change the panel title of the serial.uir to something else.
(2) Running an EXE built with CVI requires that at least the CVI Run-Time Engine is installed on that PC.
(3) CVI comes with a File I/O that contains all you need.
(4,873 Views)
the title is not getting changed. i have tried to click at tiltle but it is not having any text format in it.
(4,870 Views)
If you haven't worked with CVI right now: Have a look at the "Getting Started with LabWindows/CVI" manual that comes with CVI.  This thoroughly answers all basic questions.
(4,869 Views)
(1) Open the *.uir.
(2) Select Edit >> Panel.
(3) Specify the Panel Title.
(4,868 Views)
yes i got 🙂 thank you
can i save the data that i receive from my com port,as i was able to save the data in hyperterminal. can i also save in it.
(4,863 Views)
I am not informed about the file format that hyperterminal uses.  However, CVI allows wiring to files.  To get a list of functions that deal with file handling, press <Ctrl-Shift-p> to get the "Find Function Panel" dialog.  Type in "file" and press the "Find" button.  This will open a list of funtions that contain "file" in their name.
(4,858 Views)
