LabWindows/CVI
Choosing a name when saving to a file
Hi,  I was wondering if someone could help me with my problem. I am tryin to saving data to a file. On my uir i hv a option for you to choose where and what file name you want. but incase one doesnt go and set it up but instead just starts the program. I have it set so that it automatically by default saves it in the folder and a default name, below is the code for it:
   if(file_sel==0)
   {  //if file not selected, saves to data.log by default.
          file_sel=1;
          file_opened=1;
          file_handle = OpenFile ("Data.log", VAL_READ_WRITE, VAL_TRUNCATE,
                                                       VAL_BINARY);
But i was wondering if i can hv the file name followed by the time it was saved....well i know windows itself puts a tag....i would like to have my own after say Data....perphaps date and time....or something of that sort! because currently my problem is that say i start the program n then stop it....if i start again without quiting it appends......but say i quit and the next time the user starts it will erase the previous log but where as if he chose the file then it will ask him if he wants to over write it...so that part is fine...its only if the user doesnt select the file.
I would apprecaite if someone can help me or give an idea to go round this.
k1_ke
Message 1 of 15
(4,802 Views)
Hi k1_ke,
The library functions DataStr() and TimeStr() can help you out:
char filename[MAX_FILENAME_LEN];
if (file_sel == 0){
    file_sel = 1;
    file_opened = 1;
    Fmt (filename, "Data_%s_%s.log", DataStr(), TimeStr());
    file_handle = OpenFile (filename, VAL_READ_WRITE, VAL_TRUNCATE,
                                                       VAL_BINARY);
Message 2 of 15
(4,794 Views)
Sorry, it's DateStr() instead of DataStr() Smiley Happy
Message 3 of 15
(4,789 Views)
Hi Wim,
Thanks for your reply. I tried what you mentioned but i get a error...Missing Prototype
   if(file_sel==0)
        file_sel=1;
       file_opened=1;
                                                       VAL_BINARY);
I would appreciate if you could look at it again.
k1_ke
Message Edited by k1_ke on 01-18-2006 11:49 AM
Message 4 of 15
(4,790 Views)
Hello k1_ke
Pull down the Library menu in the menu bar and select 'Utility...'. In the 'Select Function Panel' window that pops up, select 'Time/Date...'. You should find the functions DateStr() and TimeStr() there.
Greetings,
Wim
Message 5 of 15
(4,783 Views)
I see now you typed DataStr() instead of DateStr(), that was my mistake Smiley Sad . Just adjust that and it should work.
Message 6 of 15
(4,779 Views)
Hi Wim,
Sorry to keep bothering you, yeah i found that typo just after i emailed you. After making the changes it still doesnt work...well it passes that line now. My program compiles with no errors...i start it and when it reaches the file to openfile it crashes n get the following error
NON-FATAL RUN-TIME ERROR
Library function error (return value == -1)
Invalid argument
Also when i read the help file for OpenFile it says CAUTION: The Windows SDK also contains a OpenFile function. If you include windows.h and do not include formatio.h, you will get compile errors if you call the OpenFile function. but i need formatio.h for other things.
Let me know what i should do
k1_ke
Message 7 of 15
(4,784 Views)
Hello k1_ke,
If the function OpenFile returns the value -1, an error occurred (read the OpenFile help page).
If you want to know what goes wrong, use the following code:
int error_nr;
  if(file_sel==0)
        file_sel=1;
       file_opened=1;
       DisableBreakOnLibraryErrors();
                                                       VAL_BINARY);
       EnableBreakOnLibraryErrors();
       if (filehandle == -1 and (error == GetFmtIOError()))
Message 8 of 15
(4,759 Views)
Hello k1_ke,
int error_nr;
  if(file_sel==0)
        file_sel=1;
       file_opened=1;
                                                       VAL_BINARY);
Message 9 of 15
(4,760 Views)
Smiley Mad Sorry, I accidentally pressed the Tab Key and then kept hitting the space bar, causing 100 messages to be posted... Smiley Mad
I planned to write the following:
Hello k1_ke,
int error_nr;
  if(file_sel==0)
        file_sel=1;
       file_opened=1;
                                                       VAL_BINARY);
              MessagePopup ("Error",  GetFmtIOErrorString(error));
Greetings,
 Wim
Message 10 of 15
(4,758 Views)
