LabWindows/CVI
ClientTCPRead return value
hey
i am building a tcp client, i used ConnectToTCPServer with a callback- which fires periodically so i used ProcessTCPEvents in an loop on every read.
the server accepts AT commands and responds accordingly-
to reduce the chance that  i will read upon my next ClientTCPRead a message that was sent after a timeout i first clear the buffer
e.g:
I send A
the server didn’t respond in a timely fashion
 I get a timeout error (pass it on to the user)
in the meanwhile the server sends B as response to A, (no ProcessTCPEvents is yet to be executed because no write is done).
I try to write C ,fire ProcessTCPEvents and then read B and D- C’s reponse).
I want to read only D so I need to somehow clear old messages.
Code to clear the buffer:
while(1){
            G_Connection_Error=ClientTCPRead (G_handle, G_Receive_Buf, BUFFER_SIZE, G_timeout);//flush tcp buffer stack
            if(G_Connection_Error>0) OutputToText_ep_printToTextBoxColor(RED,"out of order message: %s.\n",G_Receive_Buf);
            else break;
number of questions:
1. what does a 0 return value means- there is a 0 byte message-can there be a situation where ClientTCPRead returns 0
2. is there a better way to flush the tcp buffer
3. is there a way to ensure that on every message the callbak func will be fired without the ProcessTCPEvents
Thanks in advance
Moshe
(4,242 Views)
Hello Moshe,
1. ClientTCPRead Return indicates whether the function was successful. Unless otherwise stated, zero represents successful execution and a negative number represents the error code.
2. I believe you are doing it the right way.
3. That is the correct function to call
(4,224 Views)
thanks
a follow up for the first answer:
ClientTCPRead  returns the number of bytes read, if the returned value is zero what does it mean?
if no data was read  the returned value should be a timeout (-11), if data was read the return value must be larger than zero
and thus i ask what does a return value of zero mean?
BR
Moshe
(4,212 Views)
If you pass a 0 for the data buffer size, then ClientTCPRead would return 0. But otherwise, it should return non-zero values.
(4,201 Views)
