LabWindows/CVI
Clock Edge Interrupt Function (?)
Hello Labwindows community,
Currently using Labwindows CVI 2012.
I wanted to see if there was a function, in particular with the NI-DAQmx library (but not limited to), that allows for the detecting of the falling or rising edges of a pulse that occurs in microseconds. Is there an interrupt function or something similar that I can use to detect this and if the event occurs, to call a callback function?
Vincent
(3,627 Views)
Did you try Help >> Find Examples... ?
Maybe ReadDigChan-ChangeDetectionEvent.prj could be a starting point.
(Just guessing, I never used such a function.)
/* Nothing past this point should fail if the code is working as intended */
(3,596 Views)
^ that example should show what you're trying to do.
Also, make sure your hardware is supported by change detection. You can take a look at this document to check:
Digital Change Detection in NI-DAQmx
Francine P.
Applications Engineering
(3,587 Views)
Thank you for the response CVI-User and francine.p.
I took a look into the project description for the ChangeDetection.prj and noted that it wasn't something I was looking for. My project ran out of room for additional digital input signals. I wanted to see if there was a way we can measure the event change with a digital output signal, but scrolling through the functions, it seems limited to digital inputs only.
Thank you both for the feedback, I think I can use those resources to research further.
Vincent
(3,579 Views)
