LabWindows/CVI
Close windows session when exiting my program
I would like to close the current Windows session when exiting my program.
Have you got any solution ???
(4,219 Views)
This sort of thing can be done but you will have to dive into the Windows SDK functions to do it. I doubt that CVI itself has anything in its libraries to support this functionality.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(4,211 Views)
Along those same lines, try the ExitWindowsEx function from User32.dll.
Link to microsoft:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/sysinfo/base/exitwindowsex.asp
(4,207 Views)
I think ExitWindowsEx function does not work in XP.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(4,195 Views)
This link from Microsoft says it does work in XP. Review the parameter options to see if any apply to your case.
(4,192 Views)
ExitWindowsEx works (even with XP...) and it is exactly what I was searching for. Thanks !
(4,184 Views)
