LabWindows/CVI
Code Analyzer for labwindows
Hello ..... My question is , as we use cpp check to analyze C/C++ code....is their any tool available by national instruments or by other company to analyze code written in labwindows...
SA
Message 1 of 11
(6,352 Views)
Try Unity for static code analysis..
Message 2 of 11
(6,290 Views)
Since CVI has been using clang compiler since version 2013, I think the best option is to use Clang Static Analyzer.
Does CVI supply an out-of-the-box integration for it?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 3 of 11
(6,279 Views)
HI Vix, I would like to give a look to the tool you mention but the antivirus claims the page is risky due to some trojan in the downloads Smiley Frustrated
Have you an alternative, more secure link?
Message 4 of 11
(6,269 Views)
Hi Roberto,
which antivirus do you use?
If it is McAfee, it's quite common to have false positive and you should submit the link to McAfee.
In a couple of days you should be able to access the page.
The page itself allows you to download a build for Mac OS X and source code for other platforms.
If NI didn't include it in CVI, I think you must rebuild it from sources and it could be a little bit frustrating.
Vix
Using LV from 7
Message 5 of 11
(6,266 Views)
It's Norton Security and I don't seem to see a link where to ask for a page review...
Message 6 of 11
(6,261 Views)
Maybe this page, with option "A4 - When browsing the web" can work.
Do you have the chance to try?
Vix
Using LV from 7
Message 7 of 11
(6,258 Views)
thankx....
Message 8 of 11
(6,245 Views)
I've just remembered that some years ago I created a product suggestion on this topic.
Feel free to give kudos if you like.
Vix
Using LV from 7
Message 9 of 11
(6,226 Views)
 The PVS-Studio analyzer works (with Clang), too.
/* Nothing past this point should fail if the code is working as intended */
Message 10 of 11
(6,219 Views)
