LabWindows/CVI
Color of popup
the function MessagePopup from the User Interface Library has the background selected in the windows settings of the screen. How can I determine this color to use it for other purposes?
Michael
(3,780 Views)
Hello
If you need to customize the appearence of your popup panel, you can create your own panel and install it as a popup by using the InstallPopup() function. You can configure the font settings on the default popup box, but not its color. You can use the installpop like so:
panel1=LoadPanel(0,"1.uir",PANEL1);
InstallPopup(panel1);
GetUserEvent(1,&panelID,&controlID);
RemovePopup(1);
Hope this helps
Bilal Durrani
NI
(3,766 Views)
Instead, if you want to know which color is the system popup background, you can use
GetWindowsColor (SYS_BTNFACE, &color);
(3,764 Views)
I forgot to say that this function is in the Programmer's Toolbox that comes with CVI (cvidir\toolslib\toolbox\toolbox.fp)
(3,760 Views)
The popup panel is the windows color because it has the panel attribute ATTR_CONFORM_TO_SYSTEM set. You can make any panel that color by setting the same attribute. You can then get the color by getting the attribute ATTR_BACKCOLOR of the panel.
- jared
(3,758 Views)
Thank you Roberto, that is what I was searching.
Michael
(3,756 Views)
