LabWindows/CVI
Combining NIDAQ installation with a distribution kit
I've created a LabWindows/CVI application that uses a multifunction DAQ. I would like to minimize the steps required for installing only the necessary files, including DAQ drivers, for this application to run on a target machine, where NIDAQ is not necessarily installed on this target computer. What would be the optimal approach to achieve this?
I've scrounged the NI site for information, but I haven't been able to find a straightforward example. I understand the basics of a distribution kit. I've also seen references to "silent installations" for NIDAQ, but I don't really understand exactly what this is.
I understand that this might be a rather involved procedure, but even a basic overview would be a great
help. Thanks for your time!
(3,046 Views)
Greetings,
To install NI-DAQ in the same installation process as your CVI application, you will need to use a batch file (.bat). A batch file is a script of DOS commands that are executed when the file is called. There is a great deal of information on the Web concerning the creation of batch files.
Good luck with your application.
Spencer S.
(3,046 Views)
Unfortunately, there is no easy (or hard) way to include the DAQ driver with the distribution kit in CVI or LabVIEW. NI-DAQ is a huge and complex driver and there is no straigthforward way to link to it from the distribution kit. Currently we require our users to install NI-DAQ directly from the CD or from NI's website. This might improve in years to come but for now I would suggest that you install DAQ separately. Or you could also write a small executable that would be scheduled to run after the dist kit install. That executable would just prompt the user to insert the Driver CD.
I'm sorry I don't have a better answer for you. We are definitely award of users needing this feature and are working towards a solution.
Azucena
NI
(3,046 Views)
