LabWindows/CVI
Combo Box Input
Hey, I'm trying to save a user's name in a combo box so that the user can just selet their name from the drop down menu next time they use the program. Is the a way to edit the attached VI such that multiple entries of the same name (array value) are not saved in the array/Combo box??
(3,635 Views)
Hi WEvans,
this forum is dedicated to CVI: you will get better and quicker respenses in the LabVIEW forum. Anyway, in my opinion you should post-process your strings [ ] array after the while loop and before passing it back to the combo box to remove duplicated elements (you could for example sort the array and then scan it in a for loop or a while loop to search for consecutive identical elements and remove one of them).
(3,617 Views)
I did a variation of your suggestion. Appreciate the help.
(3,578 Views)
