LabWindows/CVI
Command protected Error
Hi
I am learning  LabWindows.
I am trying to fetch the test result from CMW 500.
However, when i am calling the function to fetch the test result.
I am getting error message.
Such as  "-203 Command protected, FETC:GSM:MEAS1:MEV:LIST:MOD:BPOW:AVER? "
I am not really sure the casue to return command protected error.
Does anybody know the casue to return the error ?
(4,557 Views)
That looks more like an error raised by the external instrument than like a CVI error.
It appears that you are using some sort of SCPI command to query the instrument: this page can possibly give you an explanation. In any case, you should search for the cause of this error inside interument documentation.
(4,538 Views)
I was looking for this page!!
(4,513 Views)
