LabWindows/CVI
Communication between CVI and PLC Siemens S7
Hello everyone, I would like to know if there are drivers for communicating a program written in CVI and a Siemens S7-1200 PLC with Profinet protocol.
Tnx a lot
Kind regards
(3,639 Views)
Hello, 10 months later, and I am looking for the same since several days.  Did you find any solution in the mean time?  Thanks for your help!
(2,970 Views)
There is no LabWindows/CVI specific driver available for this and one approach to tackle this would be to use the Snap7 open source library if you can use standard TCP/IP connection.
It may require a little bit of tinkering with the headers of that library to make it compile in LabWindows/CVI but definitely should be possible to do.
If you absolutely require a Profibus connection you may have to tinker with this device here: https://www.kunbus.de/df-profi-ii.html
Their C API can be definitely also called from LabWindows/CVI although it may not be trivial. Definitely not like accessing the typical LabWindows/CVI instrument libraries.
For Profinet connection I would start looking at this: https://support.industry.siemens.com/cs/document/99684399/sinamics-g-s%3A-profinet-connection-with-l... It is for LabVIEW but you can also call the DLL from LabWindows/CVI.
Rolf Kalbermatter  My Blog
(2,927 Views)
Wonderful complete and clear answer.  I will study, implement, test and come back to you.  Many THANKS !
(2,916 Views)
