LabWindows/CVI
Compare Time and Date String
I would like to compare date and time from .txt file. How do i change string date and time to actual time? Is there any CVI command that perform time comparison?
(4,425 Views)
You could parse the string of date and time and conveniently fill the fields of a struct tm, then use mktime () to obtain calendar time and use difftime () to compute the difference. The result of this function is in seconds, so you may need to reformat it in case you want to show it in hh:mm:ss or other formats.
(4,418 Views)
